LED lighting - Interior Courtesy Lighting
(2 reviews)
LED Lighting - Courtesy Lighting
Parts listing
Dome light bulb install you need to carefully pry the driverside of the dome light lens downward. It will hinge on the passenger side. Simply pull the bulb and install the new bulb. If it doesn't light up turn it around 180 degrees and install again.
Map lights you need to open the garage door panel. Inside there are two tabs and push to the opposite side and carefully pull the overhead panel downwards slightly to release the locks. Once you are done this it pulls rearward to release the panel from the rear side hooks. Be careful older panels might be brittle and easy to break. Now there is a plug you can disconnect the panel from the wiring. There is set of Phillips screws holding the lights in place. Once you remove each you can simply change the bulbs out. With the map light still released from the panel, you want to plug it in and test the blubs. If any of them don't light just turn them around 180 degrees.
Before, stock OE lights
User Feedback
   1 of 1 member found this review helpful 1 / 1 member
great article.  Makes the cab much brighter.
Thanks to this article I was able to not only upgrade the bulbs without breaking the overhead console, but actually fixed one of the map light switch mechanisms!
