- Replies 5
 - Views 2.3k
								rburks 2 posts
								dave110 1 post
								mulcher812 1 post
								TFaoro 1 post
I'm wondering if there would be any issue with replacing the whole "T" line assembly with 2 barbed banjo fittings (maintaining the stock check valve bolt at the VP44) and 3/8 3 way barbed T fitting and some 3/8 fuel hose. I bent my assembly pretty good when I pulled the head (forgot to unbolt the line bracket at the head when I pulled it), and I think I'm getting air in the system, as it now takes about 15 seconds to start in the morning. This is different from the barely touching the key I had before pulling the head.
To replace the whole assembly from Cummins appears to be about $130, and you are still dealing with the crummy hard-line and rubber washer setup.
Edited by Nates1999
