Part compatability
Anyone know if the front bumpers and fenders are the same the whole way through the 2nd generation (94-02) ? I may have found a parts truck but I'm pretty sue it's from the 12v years and I thought I read one time the fenders were different.
  • Replies 5
  • Views 1.7k
Not sure but if you shop Amazon it will group it with your 99 if it fits
Then you'll know
I know fenders from a 95 will fit on a 99 no problem. The front bumper is the same except the mounting brackets were a little different. My 99 brackets looked like they would bolt right on the 95 bumper but I never did try.
There was some differences in panels but not much I do believe that began in 99. The sport fenders are for sure different to allow the dual bulb headlights to fit.
Also the Sport bumper and grille are also unique to the sport line but the bumper and grille can be swapped.
Then you'll know
Be carefull with this because I have had Amazon say it fits when it clearly did not.
Thanks for the replies. I'd like to just put a Ranch Hand or similar bumper on but dang!, so much $$, and you almost never see a used one.
