Well guys hopefully this weekend I will learn how to install a door glass in my 2010 1500 Dodge hemi. Was doing yard work and had the bagger vac on the zero turn mower and it must have slung up a rock and took out my passenger side door window, :cry: ordered one right away from Rock auto and hopefully it shows this week and I will put together some pics as I learn myself how to do it.
  • Replies 4
  • Views 2.1k
Get yourself a couple of kids and friends, a bag full of army men and a pile of rocks. Then it wont be your fault. Where's the emoticons when you need one?
Just got shipping notice and won't be here until next week.......................:(
Forgot to take pics but oh well, got the window in and after going slow and inspecting as I went it wasn't too bad a job, it is a neat way they do the regulator unit. One takes the inner door panel off then inside there is a second door panel that mounts to the inside of the door, there are several electrical connectors one needs to unhook for various things, the regulator unit is actually part of the inner door panel and comes out quit easily once I figured what all to unhook and how, even the door latch assembly and mechanism comes out with it, only thing that needs to get un hooked it one snap linkage for the outer door handle to the latch mechanism and they supply a hole just the perfect size to get in to do this. All in all it went well, took about 2.5 hours in total and about an hour of that was cleaning up all the broken glass off the floor as it fell out and vacuuming out the inner door ect.
