I just got done pulling my 5th wheel for about an hour and when I stopped I noticed that there was a good amount of coolant splattered down the underside of my truck. As far as I can see it is not coming from the radiator or any hoses. It is wet on both sides of the motor and not mostly down low. My question is if the water pump was leaking would it leak down inside the front cover and come out the bottom. It is very hard to tell where this is coming from.
  • Replies 2
  • Views 1.5k
  • joecool911
    joecool911
    Do you have a pressure tester? That's the best way to find leaks. Do it cold so it doesn't evaporate.
I dont but I'm sure I could find one. Well its going to sit all weekend and then pull the camper home so hopefully it makes the trip back.
