- Replies 2
- Views 2.8k
Ilikeoldfords 1 post
01cummins4ever 1 post
I picked up some 5000 k axles for my car hauler, swapping out the 3500 k axles. The deal is that the new ones are to narrow and I am hoping to extend them. I have a few options, one is to cut them in center and put a sleeve inside,or box the outside with a larger diameter pipe. Or option two is too cut the spindles out of new axles and weld them to a new pipe cut to the proper length I need to fit the trailer. being careful for a true alignment when welding on the spindles, also I know that some trailer axles are cambered and if I use new pipe I will not have a camber in the axle, so dont know if this is a good option or not. Or option three (which would be the most expensive) and the deal I got would no longer be a good deal, is to buy new straight axles with spindles already installed.
The trailer is a 2006 Top Hat 18' with dove tail, it is a very well built and very capable of handling the extra payload, but with the 3500 lb axles I'm limited with what I can haul. I bought this trailer new at an auction years ago and when going home I noticed the trailer brakes did not work and crawled under to find the wires had been cut and did not match up to the wires on axles, and led me to thinking some one may have swapped out axles before I got it ,and maybe it was built with heavier axles, I dont know, No tag for weight rating anywhere. but anyway its going to get the heavier axles one way or another, Just wondering if anyone has dealt with extinding axles or got any Ideas
