- Replies 8
- Views 2.1k
dripley 4 posts
jokra 3 posts
hawkeye213 1 post
The line should go thru the firewall at one of the hvac lines. You can remove the glove box and it should visible on top of the hvac box. It does look melted. Mine broke near the same spot as your is
Everything was working fine. The blower motor has only run on high for a year or so. My blower motor started making a funny noise like the squirrel cage was rubbing against something. So I pull the blower and disconnect the electrical plug and pull the resistor also while I am down there. The resistor just need a spot soldered back which I did. The blower motor has like a rats nest of insulation in the squirrel cage. I did reach up thru the blower housing and feel around to see if there was any other junk up in there and there wasn't. I put everything back together and the blower motor blows on all speeds now and the noise in the blower motor is gone everything is great except it only blows out the defroster vents no matter what I select with the switch. I was only working right there where the blower motor and resistor was.I have had to knock something loose right there but cannot figure out what. Thanks for any help you can give me .
Update
Ok never mind. I was testing it with just the key in the on position. I just went out and actually started the truck and it works just fine now. It even works now with the key only in the on position. Weird but I'll take it.
Edited by hawkeye213
