- Replies 2
- Views 7.3k
Me78569 1 post
woodtrucker 1 post
Was out doing some running around this morning and had to jump out in to some traffic and get down on the right pedal. I was thinking I had a stock truck but happened to look in right rearview mirror and noticed some (not a lot) of black smoke. Is this normal on a stock truck or is that an indication that there is a programmer on the truck?
Also, once I was in the flow of traffic I noticed the MIL was on. I pulled the code when I got to work and it's a P0234 which I read could be MAP sensor, stuck WG or an actual overboost condition caused by a programmer. Is there a way for me to know if there is a programmer installed? Also, I called Dodge to price a MAP sensor and he said on a diesel it's a turbo boost sensor. Is that correct? Thanks in advance.
