Bad steering colunm? shift indicator out of whack, tight steering
- Replies 9
- Views 3.9k
You my need one of these http://www.rocksolidramtrucksteering.com/ and this is how you install it http://www.pavementsucks.com/threads/rock-solid-ram-steering-fix-install.336866/. I agree that
Check the bushing in the engine compartment end. I would pop the steering shaft off and rotate the wheel. Just make sure not to go too far as there is no internal stop. I doubt it is the clock spring.
So this problem has slowly been getting worse,
Little run down, beginning of all this. so every time ya go to turn, it makes a squeaking noise, left or right doesn't matter.
As time went on, it got a little worse, then when you started turning left, ( still makes the squeaking noise) the steering wheel would tight up, not alot but enough to notice in the wheel and got really annoying, it wouldnt tighten up turning right, normal as could be.
Well now it's getting bad, if you go to turn left, it'll pop out of drive into neutral, go to turn right it, it wants to pop out of drive and has, also the gear indicator has been funky,
When you go to put into park, the indicator stays on drive, or 1st gear, the indicator in neutral. Wants to stick.
Couple things I'm thinking it could be,
Bad clock spring,
Steering column ujoint bad? But that doesn't explain why it would pop out of gear.
Cable linkage out of whack?
Bad steering column in general.
Now I haven't torn into anything yet, but it's going to be my weekend project, just need to know what I should be looking for/checking.
It's to the point now where it's almost to bad to drive.
Thanks in advance!!
