Headlight Relay Wiring
- Replies 9
- Views 12.5k
Waydin_Stewart 6 posts
Mopar1973Man 3 posts
I know I know, I have alot of posts on different subjects but I want to get everything lined out of this truck. I still haven't messed with the oil pan gasket and I need a front timing cover and tappet cover gasket aswell. I am curious of how to wire up a relay for the headlights on my 1998 dodge. Its not a sport model it originally had the 9004 lights in it but recently got some aftermarket cleared lens with projector. It has a dual beam setup but still uses the 9004 plug. Works great! I am gunna do the high low mod and have both on at once by using the wire splice under the steering wheel and want to take load of switch aswell so I want to add a relay to driver and passenger side. How do I go about doing this.
