Radio and power mirrors not working
I just put a new drivers side fender on my 02. Now my radio and power mirrors will not work, I have checked all the grounds and the fuses. I just wondering if anyone has any insite ? Thanks
  • Replies 4
  • Views 2k
  • Have you checked the IOD fuse? It is #12 in the fuse panel in the dash and has a plastic cover on it. The cover on mine is black.
I don’t see a master fuse under the hood. I also noticed my dome lights are not working either. I checked for ground through continuity in my mirrors they do have ground. I’m thinking it’s a fuse somewhere. I’ve checked and changed all the easy ones.
You are the fuc:ing man THANK YOU SO MUCH. That was it obviously.
