- Replies 20
- Views 10.2k
rburks 9 posts
Mopar1973Man 7 posts
dracozny 3 posts
ISX 1 post
Does anyone have a wiring diagram for the Headlights.. I HAVE JUST LEARNED OUR TRUCKS HAVE GROUND SWITCHING SYSTEM "Meaning the switch in the Cab interrupts the Ground circuit and not the power... HAVING TROUBLE IDENTIFYING THE 3 SMALL WIRES IN OEM #9004 PLUG, NEED TO HOW IT COMPLETES THE CIRCUIT SO I CAN TRIGGER THE RELAYS WITH THEMI am installing new Sport Headlights... Made my own Wiring Harness w/Relays using 10 & 12 Gauge Wire.. 14gauge on the Trigger wires. sordered all terminals & connections and used Marine Heat-shrink tubing which has a glue in it that melts & sqeezes out the ends to bond to the wire insulation.. WILL POST PICTURES AND SPECIFICATION'S AND WHERE TO GET ALL PARTS WHEN I AM FINISHEDRichie
