Suspention Bolt Backed out
Hi All,
             New to me Truck.  I was removing the Edge Transmission Temp sensor Wire when crawling out I noticed that the top bolt in the 4 link #4 in Illustration was backed out, right hand side.  Aside from screwing back in with Locktitie is there a way to unload the link so I don't Screw it up?  I assume (That word.) that Jack it up and support the frame and then just unscrew locktite it and back in she goes?
Edited by int3man
  • Replies 2
  • Views 1.5k
You've got it... Jack up the frame and let the axle hang free. You might have to adjust the axle height with a floor jack a bit to align the bolt again. I've done control arm replacements but typically I do it one control arm at a time.
K Thanks Better to ask than assume!!  I've not done 4 links.
Did a bomb on my daughters car, Busted the top threads off the Left Front Strut , had a stress riser where the threads started!  that was a PIA!!
Thanks
Michael
