- Replies 6
- Views 3.5k
Mopar1973Man 2 posts
REFLancer 2 posts
keydl 1 post
bahrfly 1 post
Well as you know i had a problem a couple weeks ago with a knock and a whole lot of blowby I was pullin a hill with my 8000# trailer all my gauges read good oil pres,egt@1000 boost@30 edge comp set@ 2-4 . Got the motor out and found #1 piston with stuck rings scored walls `
what is the way to go bore and sleeve or short block?? this motor only has 58000 miles ??? :confused:
