Help with blend door and vacuum line havc box
- Replies 5
- Views 1.3k
slowpokedodge 3 posts
dripley 2 posts
Replacing the evaporator core and heater core on my 98 24 valve truck. I have everything loose except the 2 bolts under the dash. There is a cable going to the blend door from the heat and cool knob that I cant figure out how it comes loose. I can pull the cable loose from the door but how do I get it loose from the box. I have a bad habit of breaking stuff. Also having a hard time finding the vacuum line that unplugs from the drivers side. I can't see good enough anymore to do a lot of things. Thanks for any help.
