I found a part store manager that was really cool. He admitted that the new power steering pumps are not holding up good. Being all I was looking for is the reservoir seal he was nice enough to order a new pump and pull the seal off the pump and give it to me. Really cool guy.
Now as for replacing that seal you can replace the seal without pulling the pump. I removed the 2 return lines and the pressure lines. Then there is two 18mm head bolts and then a 27mm fitting that your pressure hose screws into. Very carefully just bump the reservoir and it will slide off the pump. My seal was cooked hard. It broke instantly. I lightly greased the new seal and slipped into the groove. I clean out the reservoir can with a bit of brake clean and rag. Lightly greased the reservoir lip. Slipped it over and reassembled. Filled with about pint of fluid and I was done no more dripping power steering issue!
Just wait... That little oil leak will cost you later. As the oil soaks on the rubber mounts like engine mounts, transmission mounts and even like me currently the control arm bushing. It will rot the
