Rear sway links
Replacing rear sway links.  On the drivers side do I need to move the fuel tank out of the way or did someone put this bolt in backward and I should put it back in the other way upon re installation?
  • Replies 3
  • Views 1k
So it’s currently put in from the inside out, I see no reason why it can’t go in the other way like you say.  Do you think I can I strap the rear of the tank and move it 2-3” to get that bolt out?
