Creaking squeaking door panels
Does anyone have or has dealt with the noisy door panels?  When you happen to lean on them and when you pull on them?  Any good solutions?  I replaced all of the clips that hold the panel on which improved the situation a little, but still noisy.
  • Replies 5
  • Views 1.6k
Try this, get a piece of felt material from a fabric store, Walmart  may have it, and some glue;  remove the door panel, see where the rub marks are on either the door or the backside of the panel. You then glue the felt over the marks, let dry, reinstall the door panel and test.
