Lockup switch
Okay I’m not sure I fully understand what putting in a lockup switch will do. I understand how it works and why to put it in but I need to know exactly what changes when it comes to drivability.
I guess what what I would like is a 3 way lockup switch that
1. Has completely stock lockup function
2. Can lock/unlock the t/c on demand
3. Can just prevent lockup from happening until commanded by the switch and then can unlock via brake pedal.
Is that hat how they all work? Or am I asking for something that doesn’t exist.
Ultimately I want to keep it as stock as possible for people like my wife or whoever may use my truck but I also want to be able to delay lockup until I command it or completely block it’s ability to lockup with the flick of a switch because there are many scenarios that I find the t/c wants to lock to early which causes luging, bucking, and difficulty pulling some hills.
  • Replies 1
  • Views 1.4k
  • IBMobile
    IBMobile
    I know a three way switch won't work with this set up but if you splice in an on/off switch in the orange/black wire at the PCM connector B11 would keep the lock up from happening when the switch is i
I know a three way switch won't work with this set up but if you splice in an on/off switch in the orange/black wire at the PCM connector B11 would keep the lock up from happening when the switch is in the off (open circuit) position.
