Quadzilla data link splicing
Can anyone confirm if my data link wires are spliced correctly?
I spliced the wire from truck wiring yellow/blue line with the solid blue wire(B) in the quad data link harness. I then spliced the other wire from truck wiring yellow/green line with the solid green wire(A) in the quad data link harness. There was also a black wire (truck wiring side) but i did not wire that to anything.
On the quad harness there was a 3 prong connector labeled A,B,C. A was solid green wire. B was solid blue wire. C was no wire.
Also I dont think it has anything to do with what I have done but my speedometer does not work now.
I really need to try and get this all figured out. I finally got the truck back after leaving it with a body guy for a ton of body work and paint the last 10.5 months and I really want to enjoy the truck before I have to store it for winter in 2 months.
Thanks for any help!
  • Replies 6
  • Views 3.9k
A plug on the quad (solid green) to the blue wire on the ecm side
Yellow green wire on ecm to wire b ( solid blue) on the quad.
A to A
B to B
C is ground
Are you telling me I have to swap my wires?
Edited by RdieselZ
I've looked at this diagram 10 times just noticed the A,B,C ?‍♂️?‍♂️?‍♂️
I feel really stupid rn. I hope that is all I need to do is swap them wires. That would be fantastic lol. Will find out tomorrow!
I just hope I didnt cause any damage connecting it wrong..
Thank you for your help and pointing out the obvious Me!!! ?
Edited by RdieselZ
Finally got the quad hooked up.
I had a short somewhere in my data link wires from ecm.
I cut the wires just out of the ecm and spliced the quad to that. Success! ?.
Also to note. I was misinformed on the quad data link color wires. I said (B) blue and (A) green.
The CORRECT quad data link wire colors are (B)purple and (A) pink.
So the correct connection is (B)yellow/blue stripe to (B) purple. And (A)yellow/green stripe to (A) pink.
Thank you for your guys help.
