- Replies 7
- Views 1.6k
dripley 4 posts
Hercules801 3 posts
Good Morning!
A few weeks ago I was lucky enough to find a 2001 Dodge 2500 manual 4wd long bed with 62K original miles. I drove it down from Montana to New Mexico, which I had the brake lines replaced pretty much immediately because there was a slight leak. I was driving to work and then all of a sudden I lost power, which caused the truck to stall out in the middle of the road. It turned out to be a bad lift pump, which I replaced with the Titanium Series Fass95 only to find out the Vp44 went with it. The shop I had originally had the truck brought to drained both 10 year old batteries accidentally and for some reason when they recharged them one of the batteries had the terminal reverse...
I obviously took my truck as far away as possible from them and installed both the lift/injection pump myself. I finally got the truck to turn over yesterday and it threw several pcodes:
P1682, P1687, P1693
I know some may be associated with the new Fass lift pump since it is not using the old lift pump's sensors, but I am not sure if all are associated. I do lose battery voltage in the gauge when I am driving, but I know there is nothing wrong with the batteries because they're brand new.
Additionally, it doesn't feel like the ac is blowing cold air nor is the aftermarket radio receiving power. I checked the fuses, but I do not see anything blow.
Edited by Hercules801
