No crank issues
So recently I have been having issues with my 01 not cranking. Normally if I "jumped the starter" using the brown wire she would fire right up. However things have changed. Now when I turn the key to on I get a check gauges light, and the dash show 8-10V. I tested my battery voltage and both batteries show around 12.7V. Then if I can get her to start she shuts off after less than a minute. Any ideas on what it could be?        Update: The radio also states that I have 10.7V. Could it be the battries?
Edited by TheVanillaGoose
  • Replies 3
  • Views 1.8k
  • TheVanillaGoose
    TheVanillaGoose
    So after doing some more checks I found that battery to chassis ground was 10V, so cleaned all of my grounds and battery leads. She started right up!
    Sometimes it easy stuff...
