- Replies 4
- Views 2.2k
The_Jackale 2 posts
dripley 1 post
Royal Squire 1 post
Popular Days
The later model 2nd gens did not evan come with them. Inner fenders that is.
Maybe you should consider a complete cab replacement
So I have finally brought my truck home a couple days ago, its taken almost 2 weeks since I have bought the truck!!! I have a list to follow and repair items, junk yard items to look for ect.
Today Im starting off with the Drivers side door latch,
THIS IS THE WORST I'VE SEEN. and yes that would be JB weld. WHY? No idea, but I can confirm it will not fix this apparently.
I also have rust at the base of the seats, it looks like the vapor barrier was off the drivers side door for a long time. The panel was not attached when I got the truck, and the previous owner said he did not remove the barrier.
So of course the drivers side has rust and water damage under the carpet, down below the cab mounts in the front are gone, going to be working on a way to lift the cab about 4 inches up to weld new ones in. The bed has a tennis ball size hole by the wheel, they had removed the inner fender that projected it.
So today we are taking advantage of the sale at pick n' pull to grab a list of parts from the gassers that are in there. Hopefully get a door I can cut apart and weld into mine without changing the color. Im going to measure the thickness of the floor and see if I can save it, but I think long term its going to have to be cut out. I try not to patch over rust, I'm not the best welder, but the Hobart 140 works okay with gas. And I have plenty of grinding and sanding discs.
Cannot wait to get this thing on the road. I have not posted because there's been no need due to the amazing search feature. So I figured I would do update threads instead since all my questions are already answered.
Edited by The_Jackale
