Identifying a couple wires and their locations
So my OD hasn't worked in a while and I just had my transmission built a few months ago. Took it to the shop and they said this wire is the reason it's not working. Could this be it? It's a twisted pair wrapped. I haven't found any spot where it could connect to, and I've searched top to bottom. Any help would be appreciated
Edited by Rather Be Wheeling
Pairs not single
  • Replies 2
  • Views 1.5k
  • No, that is not wiring for the OD;   That is under the dash next to the HVAC vacuum lines and may go to the HVAC control panel but twisted wires are used in the airbag system .  You need to strip back
No, that is not wiring for the OD;   That is under the dash next to the HVAC vacuum lines and may go to the HVAC control panel but twisted wires are used in the airbag system .  You need to strip back the cover and see what are the wire colors.
Edited by IBMobile
