Hi all...I am getting ready to do the W-T ground mod and have a few questions. I have an early model 1998.5 and the alternator is wired a bit different from the later models. I was able to find a picture of the connections from a member on here and also a wiring diagram of the alternator.
Do I remove the B+ cable on both sides of the junction block all the way to the PDC or just where I placed the red arrow? Then do I run a new short B+ cable from the alternator, with 140 amp fuse, to the passenger side positive battery terminal? Is everything the same for the grounding mod after this point?
Thanks for the help!
