Tach wont read past 2k RPM
- Replies 7
- Views 1.8k
Mopar1973Man 4 posts
jtrakel 3 posts
Hello as the title states my tach will not read past 2000-2200 RPMs. It seems like it ready correctly while cruising and idle but stops right around 2-2.2k. I went ahead and gave it full throttle with my quad logging at it shows it actually going to ~3200RPM with the audio sound of it hitting the limiter. Is my gauge cluster just bad or am I looking at something more in-depth?
In my long quest of fixing this truck i'll be replacing the VP and injectors in the upcoming week and want to ensure I don't have a ECM/PCM issue possibly. I've considered removing them and having them sent off for testing but I'm not getting any check engine lights or codes that i'm aware of, not sure if they can do much without having codes to provide when sending the unit(s) off for testing.
iQuad-2020-06-11-12.11.44.csv
Edited by jtrakel
