Quadzilla Max load offset
- Replies 9
- Views 2.5k
Me78569 5 posts
Unreal Summit 4 posts
Trying to get a full grasp on the quadzilla before my new injectors get here so I get it set up perfect when I get um in. I can't figure out the Max load offset. Should it lower the timing as I give it fuel based on throttle position? I looked back at my logs and when I get above my set load precent it's does drop 2 degrees below my cruise timing but starts to rise pretty quick. Is this how it's supposed to work?
Also if I want it to build boost faster should I set my low psi reduct to 5. It's at 4 right now.
Thanks for any help!
