- Replies 4
- Views 2.1k
Great work! 1 post
Sylvain 1 post
Crazy Wayne 1 post
Jungledave 1 post
Hi, i bought and install a governor spring kit, installed it on my truck, and here is the part where im confused...
The kit came with 3 spring, if i understood correctly, for a 3k kit, i dont use the small spring. Here is the issue, my pump as already been tampered with, when i took all the spring out, except the largest one on the outside, it only had 2 spring,ther was no small spring. Is it because one is missing. Or for a 3k install, there is no small spring at all in the pump?
I install all 3 of them anyway, with a auto transmission, do you think it will shift at 3k or 4k? Im asking cause the valve spring are still stock.
thx for your time
