- Replies 6
- Views 2.9k
Mopar1973Man 3 posts
evan717 3 posts
Good day all. I have a friend with an Edge CTS and the wiring harness socket failed in the back of his monitor & re-soldering failed to work even with a new harness. Does anyone know if any CTS monitor, no matter the vehicle, will work (with obviously the correct rear plug)? I would think the brain is in the under hood Edge box and the monitor is only just that: a monitor. Thank you very much.
