1500 5.2 auto no drive
- Replies 5
- Views 2.7k
Popular Days
Started the job this morning at 10.00 am fitted a new torque convertor, new bush in the oil pump and a new seal, refitted the box, tested and all is good, box in and running by 3.00pm, finished testin
My Brothers new to him 2000 1500 5.2 2wd auto of which he's had for maybe a month and I said it was a good truck (for a 1500) has just this afternoon stopped driving as in no drive forward/reverse any gear nothing but a horrible rattle whenever engine is started, this isn't a real metallic rattle it's more like a metallic rattle that has oil for lube if that makes sense
I towed him very slowly back to our workshop and got it onto the lift, dropped the pan and there is steel fillings in one spot at the front end of the pan slightly to the left side, I think the torque convertor is dead as it's been having a lockup wobble randomly, we changed all the solenoids/sensors etc in the pan 2 weeks ago to address a P1740 (IIRC). it wasn't changing into 3rd, it changed fine after everything replaced in the pan
So as I say I'm sure it's the torque convertor, oil is clear, no burnt smell, nothing slipping beforehand, got the starter off and flex plate good although I did think the convertor felt hotter than the rest of the trans but when it did fail he was 40mph down a slight grade so coasting really.
I wasn't prepared to run it on the ramps to test pressures as I feel the trans isn't toast and didn't want to pump steel everywhere
I'm going to pull the trans tomorrow
Am I missing anything ????
I hope it is the torque as a trans rebuild here in the UK is pants at best
