Eng Motor Mounts
Well it happened wrecked my 01. It bent the front part of the frame under the rad. support. Hopefully I have a guy with a frame straightener to the rescue, this will be the second time this part of the frame will be straightened. Im sure it is weak and gonna be even weaker but I have no choice but to fix it. My biggest question is where to find motor mounts? The impact ripped the left mount, I find mounts with no dampeners in them and never the same brand. Looking to buy them all together. Am I missing something here?
  • Replies 3
  • Views 1.7k
Are you looking for the bracket with the rubber bushing in side it like this?   Found at Rockauto.
Is that all there is to it? I keep hearing you get the mount then it has dampeners you add to it.:shrug:
This is what I put in mine.
Summit PTP-4-510-BL
Mirrors vibrate for a while. When you get on the skinny pedal, you move.
