Sway Bar Diameter ??
- Replies 5
- Views 1.6k
Tractorman 2 posts
Andyba20 2 posts
wil440 1 post
Popular Days
One the left side, the side that's up against the frame, is that a gap I can see, they should have some crush and I would expect to see a gap, maybe an 1/8th or so bracket to frame with the bolts jus
What should have been a 15 minute maintenance job has turned into hours of frustration. Leave it to me. Putting in new suspensionmaxx end links and figured I’d replace the 22 year old sway bar bushings while I was at it. Measured my sway bar, 34mm. Ok, go to parts store, figure even they can’t mess up non critical bushings too bad. They send me home with a set. Huge gap, 5mm, called the parts store they said it’s normal. I’ve never done a feasibility study on polyurethane, but I don’t think these are right, no way they’ll torque closed. Even online all I can find are 30, 32, and sometimes 33mm bushings for these trucks. I. Really don’t think it’s an aftermarket bar. Anyone have a lead on a proper set of bushings, and anyone else have a 34mm sway bar? Btw, the old bushings were fine, I should have left them alone.
Edited by Andyba20
