Transmission temp all over the place
I went to leave work today and noticed a hazard sign flashing on my Adrenaline display.  It was coming from the trans temp icon.  I opened it up and the temp was bouncing all over the place, anywhere from 0-220*.  I have a mechanical gauge that was still reading less than 100 and the truck had only been running a few minutes so I knew the fluid wasn't hot.  When I started driving it settled at 100* and stayed there only occasionally popping up to 108* and then back down to 100*.  By the time I got home my mechanical gauge was at 140* while the Quad was still hanging at 100*.  The transmission performed flawlessly as usual, could this be an issue with the Quadzilla or the truck computer?
  • Replies 4
  • Views 1.9k
    Trans temp lead is touching metal. There is one lead that is with a ring terminal. Make sure it's not touching and metal. I'm using the trans temp and engine oil temp. Just double check that wire.
    Remember I got that sensor in the oil filter housing to measure the engine oil temp.
  • Sycostang67
    Sycostang67
    I tried to do that but the heater core lines are too close and I didn't have enough space for the sensor to protrude without hitting them.  I remember that day very well as I had removed the factory p
You nailed it Mike, that ring terminal was laying on the metal part of the hydroboost line.  I went and secured it a little better, some day I'll hook it up to something.
I tried to do that but the heater core lines are too close and I didn't have enough space for the sensor to protrude without hitting them.  I remember that day very well as I had removed the factory plug in the hole and accidentally hit the remote start button on my truck resulting in a geyser of freshly changed oil.
