- Replies 4
- Views 3.5k
Tractorman 2 posts
wil440 1 post
Andyba20 1 post
Popular Days
More questions than answers. When and under what conditions did you first notice the ABS and brake warning light? the abnormal AC operation? How many times has this happened? Are the
A hand operated vacuum pump is a great tool for diagnosing vacuum leaks. You should find a small vacuum manifold with many connections just above and nearby the top of the valve cover. Locate the l
One thing I can add ABS codes might not be read by some code readers, high end stuff like a Snap On Modis or similar will read which I have but I also have a SO brick and that won't
2 things happening right now, could they be related? When I turn the truck on, the ac only blows through the defrost vents, if I turn the ac off and back on it blows through whichever vent I select. Also, abs light and brake light are on. No codes. ABS module was sent off to Atlanta and rebuilt a few years ago. New front brake lines 500 miles ago. GN horse trailer currently hitched up, I unplugged the trailer connector and still getting abs/brake light. 4x4 works. Any ideas on a good place to start.
edit*- took the truck/trailer down the driveway with the connector unplugged and that cleared the abs light. Ac issue still present.
Edited by Andyba20
