02 Intermittent dead pedal
- Replies 8
- Views 6k
Ironforger 3 posts
Tractorman 3 posts
Hutch24v 2 posts
UPDATE: Issue was due to a bad MAP sensor. Issue is fixed. Truck runs great now as it should. I replaced the MAP sensor with a genuine cummins part from Genos. (Had to also buy the harness adaptor
Yeah more history would help. Could be vp44 related and could be a failing MAP sensor. Codes would tell you though.
After listening to your video, I think you described the issue very well as an engine miss. In fact, I would have called it a direct engine miss - just like a gasoline engine with a misfiring sparkp
Hey Fellas,
02 cummins 3500 dually 6 speed
Intermittent dead pedal. Sometimes while driving it sputters bit or it doesn't accelerate, does not stall out, it's just kind of runs flat and pedal does not respond as it should. Intermittent. No rhyme or reason. Some days it's fine, other days seems like it only happens for the first 15 minutes after starting when the truck is cold. It kind of feels like when my APPS failed a few years ago.
Could my issue be as simple as resetting the APPS? Have not tried that yet.
More info:
Current mileage: 250,000
Installed new timbo APPS 2018 @ 226,000 miles
I checked for codes, got none. Only shows P - Pcu, P Done, P- ECU, P Done. Tried a ODBII scan tool, no codes.
I have a fuel boss mechanical fuel pump (installed 2013 / 213,000 miles and fuel gauge so my fuel pressure is definitely good. Always using TC3w 2 stroke as well.
Thoughts and opinions welcome.
Thanks!
