Fuel Pump Mount Orientation
- Replies 5
- Views 1.9k
Mopar1973Man 2 posts
IBMobile 1 post
W-T 1 post
Andyba20 1 post
Popular Days
Shouldn't matter being a long as the fuel lines are parallel to the frame and the inlet is facing rearward.
It really shouldn't matter as long as you have serviceability access once it's mounted in the selected location. The location should provide protection from road debris to prevent damage. Recently, I
Like my truck the AirDog is right behind the transfer case. Guarded by the transfer case and skid plate.
Finally moving my Raptor FRRP to the frame rail. Using the Vulcan mounting bracket. Does it matter which direction the pump hangs? Not meaning vertical vs horizontal, but can the bracket be flipped so the pump “rests” on the bracket as opposed to hangs from it?
