Mini Skid Steer Track Problem
- Replies 2
- Views 2.5k
Mopar1973Man 1 post
Tractorman 1 post
Popular Days
I have a small mini-excavator - a 2007 Takeuchi TB016 with rubber tracks. I know it is not the same, but it is similar. I bought the machine used with 1550 hours on the hour meter. Still had the OE
I know some of our members are knowledgeable and/or professionals with heavy equipment so I’ll see if anybody has any suggestions or ideas on how to fix this. I have a late 2004 Toro Dingo TX425. I pretty much just use it sparingly around the house, so it has a pretty easy life and isn’t used often. 2 years ago I was using it and the left side track slipped off. The lugs were beat up so I just bought a new track and kept going. About 2 hours of use with the new track and it slipped off too. I reread the track tensioning procedure and tried again. It worked for a few more hours and slipped off again. I’ve tried increasing tension with the same results. I inspected every component of the track system. The tensioner arm spindle bushing was worn so we tack welded it and I went ahead and put in new bearings in the tensioner wheels. The tensioner spring seems fine (not cracked). All the bogie wheels move freely. I don’t have another machine like this to compare it to, and I don’t want to disassemble the right side track for fear of messing up something that’s working fine. The link below shows the tensioner arm in the guide slot, there is play but I’ve be been told that’s normal. The other link shows the drive wheel, which looks like it “might” have a very very slight wobble, but it could be my eyes playing tricks. The pic of the track shows where the lugs have been worn when coming off the track, they probably have 5 hours of use. Can anyone think of anything I’m missing?
