Giving new life to my impact wrench
- Replies 5
- Views 2.6k
Mopar1973Man 2 posts
cummins2k 2 posts
dorkweed 1 post
So I thought I would share for those of use who use an impact wrench to make life a little easier. My hands are shot so when I wrench on my cars I tend to use power tools where possible to lessen the strain on my hands.
I was using a Kobalt 350 ft/lbs wrench but the thing is fairly heavy and doesn't make that much power. Don't get me wrong it works well for it's intended purpose and actually is quite a bit better than any Campbell Hausfeld or Harbor Freight cheapies (i.e. $40 or less.)
So I purchased a composite NitroCat 1200k after reading some reviews on them. Ultimately I was shocked at how much power it had using an older 120v 20-gallon compressor. However there was still much to be desired on stubborn fasteners that I felt the 200-900 working torque would have no problem handing. I didn't feel the issue was with the compressor because it still would go some time without cycling. The hose is a 3/8" air hose with minimal coupling and the regulator is also 3/8" I.D. Pressure was maxed at 125psi.
Well on a trip to Homedepot to get some things for the house I went by the air tool section and found a 3/8 coupler kit. They were made to screw directly into the air tools 1/4 NPT threads, and best of all it cost $10. Part number is #HDA20700AV.
I figured for 10 bucks it couldn't be a huge loss and installed them the next day. The difference was night and day. It seems the wrench impacts a lot less and it takes fasteners off now that it would have struggled with before.
I really should have the gun on a leader hose but haven't got around to it yet. That is my next project lol.
So a heads up for anyone that is having issues getting power out of an air tool, it may very well be those cheap 1/4 couplers.
