Build forum, comments / suggestions wanted
- Replies 10
- Views 4.3k
ICU_24VNUT 7 posts
Great work! 2 posts
Mopar1973Man 1 post
Hello, so I've just been going threw my truck.
Had some personal issues come up, and haven't been dumping $ into it for like over a year.
Doings mods + fixing the stuffs/ stocking up - (switches,ecm, tipm, wiring harnesses, fuel rails, mirrors... just want to get a boat load or atleast a couple ecms + tipms for spares, just cuz if it all dissappear ill be screwed.... )
Firepunk comp 2
30% ddps
10mm cp3
63/67 tater - soonish to a S464
Head bolts, fleece lift pump, reman stock long block
Ats t3 manifold W/EGT
Mishimoto intercooler & transmission cooler,
XDP Xtra cool radiator
Mishimoto boots
Efi live by firepunk
[ ^just got a retune for 10mm^]
Getting ready to go threw the steering & suspension.
Billstieen 5100's - trying movitech coils & ball joints
I've heard the 6 bolt box is wayyy better but just the red head 4 bolt box. Steering shaft,
And going to a DOR front end upgrade kit.
Dual steering stabilizer.
+ new tires & realignment during time of install.. for now, was considering a
4 link - track bars - DD able roll cage.
For Track use / tie the back end down.
But it's a tow truck, not lifted.. so I'm kinda not wanting to take it offroad and like break everything xD
Was getting like 24 mpg on the overhead on the highway with same setup with just a stock cp3, and efi live for that setup..
Other soon to get mods
One piece drive shaft
4.5k springs
turbonator s400 housing + s464 turbo
W/Exaughst brake & air compression
Cam + push rods + tappets
Hate the stock Cam, my oil life is terrible. Getting a different Cam want better oil life, was getting 3200-3400 miles in the stock 2nd gen before the oil turned pitch black.
Get like less than 1 tank of fuel before it turns black...
Broke my firepunk comp 2 ( full billet, triple disc ) got a rebuild, went to next-gen diesel for there billet triple disc... DPC's just snapped it..
DPC is dampless, NGD is dampened and still a full race converter. Didn't do a single burn out, no aggressive abuse on the trans, got like 2 years maybe 30k miles on it... broke just on cruise control
plan to send mine out to get there in-house rebuild with there own valve body + other redesigns. Looks much more promising / dependable. And get a other full billet trans but threw them this time.
HIGHLY Recommend next-generation diesel over the firepunk transmissions
Also want to build a Higher HP engine
Thinking of getting another 06 - 07 5.9 truck for a race build... but I'm thinking 6.7 w/HO pistons either 6.4 or 6.7
5.9 short block- industrial
Ported head + thread freeze plugs + 4.5k springs
Wagler rods + 1950 or machine my own rods :P
Fluid damper $857
12mm girdle $1306
ARP EVERYTHING
More aggressive Cam
( Still going threw it plan to stock up on 3rd gen parts, but I'm considering also getting a 4th or 5th gen... probably both :P )
