P0216 and P0602 codes, intermittent loss of power, weird MAP reading
- Replies 7
- Views 1.8k
Tractorman 4 posts
greenfun2 3 posts
Popular Days
It's tough to have to do the job twice, but I'm glad to hear that DAP is taking care of you. - John
My truck recently started having a intermittent loss of power, usually before the engine warms up. It also seems to be easier to stall while backing up a hill with a trailer. The check engine light never came on, but it did throw a P0216 and P0602 code. The first time I cleared the codes, there was an episode of intermittent power loss and both codes came back. The 2nd time I cleared the codes there was no power loss, and only the P0216 code came back.
The truck is a 2001 5 speed.
I replaced the VP-44 last year with a DAP pump and added a FASS lift pump. I currently have 15-17psi fuel pressure.
The alternator is about a year old, and is a 160 amp from a Durango. I checked for AC noise and it was bouncing between 0.02 and 0.06 VAC measured between the alternator charging post and the battery ground post.
One thing that I did notice that I don't understand is that my OBDLink is saying the MAP is reading ~2 atm and the boost is ~ 1 atm with the engine off, and while driving the MAP reading wont go above 75.0 inHG and the boost wont go above 22.3 psi. I got a new MAP sensor from Napa and it showed the same the reading with engine off. I didn't actually install it and drive with the new MAP sensor, because someone switched the MAP and IAT sensors around so I couldn't get my socket on the MAP sensor with it being back by the fuel return line. I just plugged the new one into the harness and turned the key on. Does this point to an issue with the ECM, or is my OBDLink reading it wrong? Since the P0216 comes back, should I reach out to DAP about warrantying the VP-44?
EDIT: Made the pictures smaller.
Edited by greenfun2
typo
