S475 turbo CHRA help!!! Turbo-wizards needed...
- Replies 3
- Views 1.2k
QuadRunnerJake 2 posts
Mopar1973Man 1 post
I'm looking at purchasing an s475 to replace my s366 I got unintentionally.. I found a boostlabs s475 83 .90 T4 for sale brand new for $600 on marketplace.... I would be using it for twins so the t4 has got to go.
I hear there are 2 different CHRA's on the t4 vs t6 turbos. That being said how would I go about swapping to a 1.10 or similar t6 housing. Need completely new bearings housing and turbine housings?? That sounds far too expensive to be worthwhile. From what I can tell the bearing housings a mostly identical except for the diameter where the exhaust housing clamps on.
Also what's the deal with the 83/74 and 87/80 and 88/96 wheel sizes. Which would work best with a 1.10ish housing? I plan on running ported hx35/s475 but will probably step up to a 62mm secondary eventually.
This medium and large frame s400 crap is throwing quite a bit of complexity into finding a usable turbo in my area used.
