Aftermarket bun toaster
- Replies 2
- Views 1.5k
IBMobile 1 post
Sycostang67 1 post
Popular Days
It’s a two wire hook up, grounded it on the floor by the seat and ran the power wire to my extra fuse block under the hood. I wanted to hook it to a switched power source so I could leave it on and i
My new Mustang has spoiled me with its heated seats but unfortunately I can’t drive it in the snow. I found this universal seat heater at work and decided to give it a try. It was pretty easy to install as the factory covers kind of snap on. I didn’t even remove the top cover, just opened the bottom and had enough room to slide it up inside. There was plenty of space on the switch panel for the new switch as well. It works great, I put it on high and it heats up quickly. I usually drop it down to low after a bit though. It costs about $70 and took less than an hour to install.
