Requirements for small compounds
- Replies 10
- Views 1.9k
yohon 5 posts
Mopar1973Man 4 posts
Sycostang67 1 post
So i have a 57/62 borgwarner sxe and i absolutely love it some day down the road I wanted to do compunds. Guess that day came because a guy at work has done talked me into buying his s476 sxe. In my brain this looks like a nice tight towing compound set up but I'm worried about pushing the limits of the transmission and the head. Transmission has a 2 year old re build with a billet single disc torque converter and a shift kit with 150 psi of line pressure and DPP transmission fluid ( actually pretty solid stuff and cheaper then atf) head bolts are the s2000 equilivent head studs. What i cannot find is a clear answer on if my truck will hold together with this combo and what kind of power it would make. I can't find any dyno results for the sxe turbos in a compound set up . I called DAP and they were great said I would lose the input shaft on the 47re before anything. Called DPP and they seamed like they really wanted to sell me a o ring head. What's yalls experience? Am I asking for trouble?
Could the quadzilla be used to limit power?
