Different thickness injector washers?
- Replies 5
- Views 2k
Tractorman 2 posts
yohon 2 posts
Mopar1973Man 1 post
Popular Days
This photo is of a typical 12 valve engine. No crossover tubes. Fuel line are connected directly to the injectors, so injectors can be shimmed. John
My guess is that if you change the height of an injector on a 24 valve engine, the connection point of the crossover tube to injector will be misaligned. John
Has anyone messed with different thickness injector washers on 24v? Doing some searching and it's a thing for 12vs but I can't find nothing on 24vs. The theory is the further in or out of the hole the injector determined where the spray pattern hit in the bowl of the piston.
