NAPA 3858XE Fuel Filter
Be aware, I just found out the new filter I picked up this morning is defective. How? If you pull the old filter off the lid, it typically takes some force to pull the filter from the lid. Now, the new filter head that fits into the filter lid is too small and will fall out when just inverting the lid to install. Do not use these filters, you could be stuck digging the filter out of the filter can.
I had pulled the last two filters they had to try them all them are too small. Now I even check my local repair shop in Riggins, ID and they have the same issue with the filters too.
Just a heads up warning.
https://www.napaonline.com/en/p/FIL3585XE?srsltid=AfmBOor2fo7JREB0ssAAUaSx9TJkw3XmEsldEQTuiajjlhuPE-pqkqsb
  • Replies 2
  • Views 676
NAPA doesn't make that filter. It's a reboxed Wix filter. NAPA adds the prefix FIL and drops the first number, in this case it's the first 3.
NAPA gold Fuel Filter Part #: FIL 3585XE
WIX® 2006 Dodge Ram 2500 - Fuel Filter
Manufacturer #33585XE
Out here there is only NAPA. No other part stores for miles. No autozone or similar. When the filter will not hold to the lid there is a problem.
