- Replies 13
- Views 1.5k
Chickendog73 6 posts
Tractorman 3 posts
timsch 3 posts
Lund1990 1 post
I would 100% fix that before i continued. Mine was not cracked and was still pretty tight but i could force it to move. The others i couldnt. Would be a cheap and quick way to rule something out.
I purchased my first dodge cummins in December of last year. It is a 2001 3500 4x4 NV5600 with at the time 112,000 miles. I drove it 6 hours home without any hiccups other than the crappy steering which i have since fixed. In January i wrecked the truck coming off of a completely iced over hill and ran backwards into a rock wall doing 55+ mph. The truck drove home afterwards. Once i got it home and fixed the busted lights, the vp44 went out all at once and it died in the road. I install the upgraded thoroughbred diesel VP44, billet tappet cover, and a fass 165. My truck has not ran right since. It has a stutter now. When between 1700-2200 rpm it will randomly stutter almost like its cutting fuel for a split second. In the process of tracing down the problem i find out with my scanner that once my truck warms up to operating temp all my sensors go nuts. All sensor voltage, the ecm voltage, and the vp44 voltage will spike straight up and down repeatedly going from full voltage to no voltage until the truck cools off. I dont believe the 2 issues are completely related because the stutter is there even when the voltage trends are showing good. I have had multiple people look at it, spent countless hours testing voltages, moving grounds, hooking and unhooking stuff, and even sent my ecm off to be checked ($600) and can not come up with a solution. I want to love this truck so bad but i cant even remember what it was like to drive when it was doing good. Please someone help me diagnose my issue. I think at this point it could even be the fact that i am so deep in i could be overlooking the obvious. Just an fyi i have a fuel pressure gauge inline around 1.5’ before the vp44 that never drops at any point. It shows a constant 15 psi. I have tested the red/white wires from the pdc and all show almost 14 volts even when my scanner is showing dips. I doubt it had anything to do with it but my rear abs sensor is out. Havent got around to replacing yet. All the issues occur with or without the edge comp box. So far i have ran let the truck idle while watching the trend and unhooked my map sensor, abs module, and coolant sensor. Even with each or all unplugged the trend stays the same. I have taken alligator clip leads and ran grounds from each of the factory grounds to the frame, ran grounds from each of the factory grounds to the negative battery post, and hooked the negatives from both batteries together in the process of trying each factory ground. The trends seam to slightly respond when a new ground is hooked up but only for a couple seconds.
Edited by Chickendog73
More info
