Front driver's seat removal
- Replies 5
- Views 1.7k
Sycostang67 2 posts
timsch 2 posts
Tractorman 1 post
Popular Days
If you only need to remove the padding, I know the bottom part can be removed with the seat in the truck. I’ve done it twice, once to replace the foam and again to install a seat heater.
I have done the same. Can't remember the details, but I think you have to slide the seat bottom to certain positions to access four bolts (or nuts), but it is an easy task. John
I want to remove my driver's seat to modify the padding. The only video online I found showed that both seats and the center console came out as a unit. Several people in comments complained about how they weren't separable.
At some point in time they were separate. Any advice on how to best do this?
