Dead Dash - Flashing Odo - Alternator Not Charging
- Replies 13
- Views 630
Jacksbrokengarage 6 posts
Tractorman 5 posts
IBMobile 2 posts
Thank you for that information and the quick response. There should be some very helpful wiring diagrams in the manual. When you are checking connectors, be sure to inspect that there are no pins p
John, Spent some time going through the manuals today. Still scratching my head. Before I dive down another rabbit hole, let me know your thoughts on the following process. Replace all battery termi
Have you seen this article about the PCM grounds? 24 Valve 2nd Generation - Electrical PCM Ground Splice Repair
Hi All,
Dreaded issue I'm sure everyone has heard about. I am hours in to diagnosis and unsure if I am even on the correct track. Please excuse any ignorance or missed steps, I am doing the best I can with the limited skills I have.
Backstory - Truck sat idle for a few years. Runs great. Tachometer is the only gauge that works. I have the "Wait to Start" light. PCM was sent out and rebuilt, signs of over-voltage. New alternator was put in, and the in line fuse protection from this forum was installed. Went to start the truck and I briefly saw the fuel gauge work with key on power. Grabbed a new battery as the old wasn't enough to crank and I am back to the original issue again. Alternator is not charging.
I have checked and wiggled all PCM Connections, did the dash test sweep, checked passenger side grounds, unplugged abs, oil pressure, ac, and every other sensor I can find on the same system. I checked the white connection box under the clutch pedal. I am lost.
OBD shows a code for the communication error. Dash has 920,921,999 codes. I don't even know what to check for the next steps, but I am not giving up on the thing. Could I have blown my rebuilt PCM on the initial key on start?
Thank you in advance for any advise or guidance.
Jack
