Quadzilla timing.
I can say engine oil temperature will show timing. Ive managed to keep Beast with oil temperature below 180°F even with coolant temperature ranging 197 to 210°F. Simply put if your timing is off oil temperature will rise to coolant level or higher. Now if I look back at all this time on DAP 150HP 7x0.010 injectors popped at 320 bar. Im at 504k miles and still got 6 to 7% engine load at idle. Now understanding even more about tuning.
This works for Beast because of the wear on the injectors. As your injectors wear they start popping early as the spring tension loosens up. There is no way to build a tune and not have to retune over from weather change, wear on the injectors, fuel cetane levels, etc.
I've got the RV in tow and gross weight closer to 17,500 pounds. Oil temperature staying in check most ive seen was on Whitebird grade at 1,200°F EGTs and oil temperature stay right at 180°F.
Can anyone catch me?
  • Views 17
No posts to show
