Another Symptom of a failing ECM and ECM rebuilder review
- Replies 2
- Views 945
Tractorman 1 post
Snoxxy 1 post
Howdy folks,
TLDR:
Faulty ecm runs lift pump without starter bump. also DieselACS out of Hileah FL is a super good company to deal with for ECM issue.
I am here to report an interesting finding of a failing ECM that I had not seen here or anywhere before.
First and foremost, I was dealing with the dreaded WTS delay, and it finally got to about 8 seconds or more before it kicked on, so I bit the bullet and ordered a exchange ECM from DieselACS out of Hileah FL https://www.dieselacs.com
The service was friendly, and the shipping was extremely fast. Ordered Friday, and at my door tuesday morning.
I replaced the ECM, and this is where I realized my old ECM failed in 2 seperate ways!
My old ECM would have a 8-10 sec WTS delay, and after the WTS light would extinguish, the lift pump would prime.
It did this every time, and I realized this isn't normal behavior when I tried to refill the fuel bowl after my ECM replacement, and the new ECM didn't run the lift pump after the WTS turned off. I have to admit, this is when I learned that I it isn't supposed to run the lift pump until the starter bump.
Bumped the starter a couple times, calibrated the apps, and the truck runs MINT! hooked up a OBD scanner, and all was well there too.
Hope this will help someone in the future.
Phil
